Multi-Gigabit Switches
DMS-3130-30PS
16 100M/1/2.5GBase-T PoE ports, 8 100M/1/2.5/5GBase-T 60W PoE ports, 2 100M/1/2.5/5/10GBaseT ports, and 4 10/25G SFP28 ports L3 Stackable Managed Switch
DMS-3130-30TS
24 100M/1/2.5GBase-T ports, 2 100M/1/2.5/5/10GBase-T ports, and 4 10/25G SFP28 ports L3 Stackable Managed Switch
Endüstriyel Anahtarlar
DIS‑300G‑14PSW
8 x 100/1000BaseT PoE ports, 2 x 100/1000BaseT ports, 4 x 100/1000BaseSFP slots 240 W PoE Power Budget, Certified for vibration, shock, free-fall, NEMA‑TS2 Section 2, EMC
DIS-100E-5W
Industrial Unmanaged Switch with 5 10/100Base-TX Ports
DIS-100E-8W
Industrial Unmanaged Switch with 8 10/100Base-TX Ports
DIS-100G-5PSW
Industrial Unmanaged Switch with 4 10/100/1000Base-T PoE Ports and 1 1000Base-X SFP Port
DIS-100G-5SW
Industrial Unmanaged Switch with 4 10/100/1000Base-T Ports and 1 1000Base-X SFP Port
DIS-100G-5W
Industrial Unmanaged Switch with 5 10/100/1000Base-T Ports
DIS-100G-6S
Industrial Unmanaged Switch with 4 10/100/1000Base-T Ports and 2 1000Base-X SFP Ports
DIS-100G-8W
Industrial Unmanaged Switch with 8 10/100/1000Base-T Ports
DIS-100G-10S
Industrial Unmanaged Switch with 8 10/100/1000Base-T Ports and 2 1000Base-X SFP Ports
DIS-200G-12S
Industrial Layer 2 Switched Switch with 10 10/100 / 1000Base-T ports and 2 1000Base-X SFP ports
DIS-200G-12PS
Industrial Layer 2 switch with 10 10/100 / 1000Base-T ports and 2 1000Base-X SFP ports (8 ports with PoE support 802.3af / 802.3at (30W), PoE budget up to 240W)
DIS-PWR180AC
The external AC adapter AC DIS-PWR180AC is an efficient and reliable device that provides power to the DIS-200G-12PS switch.
Fast Ethernet ve Gigabit Ethernet Yönetilemeyen Masaüstü Anahtarlar
DSS-100E-6P
6-Port PoE Unmanaged Surveillance Switch
DSS-100E-9P
9-Port 10/100 PoE Unmanaged Surveillance Switch
DES-1005D
5-Port 10/100Mbps Unmanaged Switch
DES-1005P
5-Port 10/100 Switch with 4 PoE Ports
DES-1008C
8 Port SOHO Desktop Switch
DES-1008D
8-Port 10/100Mbps Unmanaged Switch
DES-1008P/C1
8-port 10/100Base-TX, (4 portu PoE) Yönetilemeyen Anahtar
DES-1009MP
9-Port 10/100 PoE Unmanaged Desktop Switch
DES-1016A/E1
16 Adet 10/100BASE-TX portu ve güç tasarrufu fonksiyonu ile Yönetilmeyen Anahtar
DES-1024A
24 Port 10/100 Switch
DGS-1005A
5-Port Gigabit Easy Desktop Switch
DGS-1005D
5-Port Gigabit Desktop Unmanaged Switch
DGS-1005P
5-Port Gigabit Switch with 4 PoE Ports
DGS-1008A
8-Port Gigabit Easy Desktop Switch
DGS-1008D
8-Port Gigabit Desktop Unmanaged Switch
DGS-1008P
8-Port Gigabit Unmanaged Desktop PoE Switch
Gigabit Ethernet Yönetilemeyen 19" Kabin Monteli Anahtarlar
DES-1016D
Unmanaged Switch with 16 10/100Base-TX ports
DES-1018MPV2
Unmanaged Switch with 16 10/100Base-TX PoE Ports and 2 Combo 100/1000Base-T/SFP Ports
DES-1024D
Unmanaged Switch with 24 10/100Base-TX ports
DGS-1008MP
8-Port PoE Desktop Switch
DGS-1010MP
10-Port Gigabit PoE Switch
DGS-1016D
16-Port Unmanaged Gigabit Switch
DGS-1024D
24-Port Unmanaged Gigabit Switch
DGS-1026MP
26-Port Unmanaged Gigabit PoE Switch
DGS-1052
48 Ports 10/100/1000Mbps + 4 Ports Combo 1000Base-T/SFP Unmanaged Switch
Fast/Gigabit Ethernet EasySmart Anahtarlar
DSS-200G-10MP
8 Port 10/100/1000 Mbps + 2 Port SFP 1000 Mbps PoE switch
DSS-200G-10MPP
DSS-200G-28MP
24 Port 10/100/1000 Mbps + 4 Port Combo 1000Base-T/SFP PoE switch
DSS-200G-28MPP
DES-1100-16
16 port kompakt 11" EasySmart anahtar
DES-1100-24
24 port kompakt 11” EasySmart anahtar
DGS-1100-05PDV2
EasySmart managed switch with 5 10/100/1000Base-T ports (1 PD port and 2 PSE ports)
DGS-1100-05V2
DGS-1100-08PLV2
EasySmart managed switch with 8 10/100/1000Base-T ports (4 ports with PoE support)
DGS-1100-08V2
DGS-1100-10MPPV2
8 x 10/100/1000Base-T PoE ports + 2 x 1000Base-X SFP ports EasySmart switch
DGS-1100-10MPV2
DGS-1100-16V2
16 x 10/100/1000Base-T ports EasySmart switch
DGS-1100-24V2
24 x 10/100/1000Base-T ports EasySmart switch
DGS-1100-26MPPV2
24 x 10/100/1000Base-T PoE ports + 2 x combo 1000Base-T/SFP ports EasySmart switch
DGS-1100-26MPV2
Fast/Gigabit Ethernet Web Yönetimli Anahtarlar (Green Ethernet)
DGS-1210-10
8 Port 10/100/1000 Mbps and 2-port SFP Web Smart Anahtar
DGS-1210-10MP
Web Smart Switch with 8 10/100/1000Base-T PoE ports and 2 1000Base-X SFP ports
DGS-1210-10P
Smart Managed Switch with 8 10/100/1000Base-T PoE Ports and 2 1000Base-X SFP Ports
DGS-1210-20
Web Smart Switch with 16 10/100/1000Base-T and 4 100/1000Base-T/SFP combo ports
DGS-1210-26
Web Smart Switch with 24 10/100/1000Base-T ports and 2 1000Base-X SFP ports
DGS-1210-28
Smart Managed Switch with 24 10/100/1000Base-T Ports and 4 100/1000Base-T/SFP Combo Ports
DGS-1210-28MP
Smart Managed Switch with 24 10/100/1000Base-T PoE Ports and 4 100/1000Base-T/SFP Combo Ports
DGS-1210-28P
DGS-1210-52
Smart Managed Switch with 48 10/100/1000Base-T Ports and 4 100/1000Base-T/SFP Combo Ports
DGS-1510-52XMP
48 10/100/1000 Mbps PoE, 4 10G SFP+ port ve güç tasarrufu fonksiyonlu Full PoE Gigabit Stackable Web SmartPro Anahtar
10 Gigabit Ethernet Smart Anahtarlar
DXS-1210-12TC
10G Smart Switch with 8-port 10GBase-T and 2-port 10G SFP+ and 2-port 10GBase-T/SFP+ combo port
DXS-1210-16TC
10G Smart Switch with 12-port 10GBase-T and 2-port 10G SFP+ and 2-port 10GBase-T/SFP+ combo port
Fast/Gigabit Ethernet Yönetilebilir L2 Anahtarlar (ME Serisi)
DES-3200-28/C1
24-Port Fast Ethernet L2 2 x SFP ve 2 x Combo 1000BASE-T/SFP port ile Yönetilebilen Anahtar
DGS-1100-06/ME
5 adet 10/100/1000 Mbps ve 1 adet 100/1000Base-T/SFP Port Yönetilebilir L2 Metro Ethernet Anahtar
DGS-1100-10/ME
8 adet 10/100/1000 Mbps ve 2 adet Combo 100/1000Base-T/SFP Port Yönetilebilir L2 Metro Ethernet Anahtar
DGS-1210-10/FL
8 10/100/1000Base-T Ports and 2 1000Base-X SFP Ports L2 Managed Switch
DGS-1210-10P/FL
8 10/100/1000Base-T PoE Ports and 2 1000Base-X SFP Ports L2 Managed Switch
DGS-1210-10MP/FL
DGS-1210-10/ME
8 10/100/1000BASE-T + 2 1G SFP Ports L2 Management Switch
DGS-1210-10P/ME
8adet 10/100/1000 Mbps PoE ve 2 adet SFP Port Yönetilebilir L2 Metro Ethernet Anahtar
DGS-1210-12TS/ME
10 adet SFP Port ve 2 adet Combo SFP/1000Base-TX Port Yönetilebilir L2 Metro Ethernet Anahtar
DGS-1210-20/FL
16 10/100/1000Base-T Ports and 4 100/1000Base-T/SFP Combo Ports L2 Managed Switch
DGS-1210-26/FL
24 10/100/1000Base-T Ports and 2 1000Base-X SFP Ports L2 Managed Switch
DGS-1210-28/FL
24 10/100/1000Base-T Ports and 4 100/1000Base-T/SFP Combo Ports L2 Managed Switch
DGS-1210-28P/FL
24 10/100/1000Base-T PoE Ports and 4 100/1000Base-T/SFP Combo Ports L2 Managed Switch
DGS-1210-28MP/FL
DGS-1210-28/ME
24 adet 10/100/1000 Mbps ve 4 adet SFP Port Yönetilebilir L2 Metro Ethernet Anahtar
DGS-1210-28P/ME
24 adet 10/100/1000 Mbps PoE ve 4 adet SFP Port Yönetilebilir L2 Metro Ethernet Anahtar
DGS-1210-28MP/ME
Metro Ethernet Managed Switch with 24 10/100/1000Base-T PoE ports and 4 1000Base-X SFP ports
DGS-1210-28X/ME
Managed layer 2 switch with 24 10/100/1000Base-T and 4 ports 10GBase-X SFP+
DGS-1210-28XS/ME
Managed layer 2 switch with 24-port 100/1000Base-X SFP and 4 ports 10GBase-X SFP+
DGS-1210-52/FL
48 10/100/1000Base-T Ports and 4 100/1000Base-T/SFP Combo Ports L2 Managed Switch
DGS-1210-52MP/FL
48 10/100/1000Base-T PoE Ports and 4 100/1000Base-T/SFP Combo Ports L2 Managed Switch
DGS-1210-52/ME
52 adet 10/100/1000 Mbps ve 4 adet SFP Port Yönetilebilir L2 Metro Ethernet Anahtar
DGS-1210-52P/ME
Metro Ethernet Managed Switch with 24 10/100/1000Base-T PoE ports, 24 10/100/1000Base-T ports and 4 1000Base-X SFP ports
DGS-1210-52MP/ME
L2 Managed Switch with 48 10/100/1000Base-T PoE ports and 4 1000Base-X SFP ports
DGS-1210-52MPP/ME
Metro Ethernet Managed Switch with 48 10/100/1000Base-T PoE ports and 4 1000Base-X SFP ports
DGS-1250-28X
24 Ports 10/100/1000 Mbps + 4 Ports 10G SFP+ L2 Managed Switch
DGS-1250-52X
48 Ports 10/100/1000 Mbps + 4 Ports 10G SFP+ L2 Managed Switch
DGS-3000-10L
8 10/100/1000Base-T ports + 2 1000Base-X SFP ports L2 Managed Switch
DGS-3000-20L
16 10/100/1000Base-T ports + 4 1000Base-X SFP ports L2 Managed Switch
DGS-3000-28L
24 10/100/1000Base-T ports + 4 1000Base-X SFP ports L2 Managed Switch
DGS-3000-28LP
24 10/100/1000Base-T PoE ports + 4 1000Base-X SFP ports L2 Managed Switch
DGS-3000-52L
48 10/100/1000Base-T ports + 4 1000Base-X SFP ports L2 Managed Switch
DGS-1210/ME Serisi
DGS-1210/ME Serisi Yönetilebilir Anahtarlar
Fast/Gigabit Ethernet Managed Stackable Layer2 + Switch
DGS-1510-28X
24 10/100/1000 Mbps, 4 10G SFP+ port ve güç tasarrufu fonksiyonlu Gigabit Stackable Web SmartPro Anahtar
DGS-1510-28XMP
24 10/100/1000 Mbps PoE, 2 Gigabit SFP, 2 10G SFP+ port ve güç tasarrufu fonksiyonlu Full PoE Gigabit Stackable Web SmartPro Anahtar
DGS-1510-52X
48 10/100/1000 Mbps, 4 10G SFP+ port ve güç tasarrufu fonksiyonlu Gigabit Stackable Web SmartPro Anahtar
DEM-410CX
Fast/Gigabit Ethernet Layer 3 Managed Stackable Switch
DGS-1520-28
24-port 10/100/1000Base-T, 2-port 10GBase-T and 2-port 10G SFP+ Layer 3 Stackable Smart Managed Switch
DGS-1520-28MP
20-port 10/100/1000Base-T PoE, 4-port 2.5GBase-T PoE, 2-port 10GBase-T and 2-port 10G SFP+ Layer 3 Stackable Smart Managed Switch
DGS-1520-52
48-port 10/100/1000Base-T, 2-port 10GBase-T and 2-port 10G SFP+ Layer 3 Stackable Smart Managed Switch
DGS-1520-52MP
44-port 10/100/1000Base-T PoE, 4-port 2.5GBase-T PoE, 2-port 10GBase-T and 2-port 10G SFP+ Layer 3 Stackable Smart Managed Switch
DGS-3130-30PS
DGS-3130-30S
24 1000Base-X SFP ports, 2 10GBase-T ports and 4 10G SFP+ port L3 Stackable* Managed Switch
DGS-3130-30TS
24 10/100/1000Base-T ports, 2 10GBase-T ports and 4 10G SFP+ port L3 Stackable* Managed Switch
DGS-3130-54S
48 1000Base-X SFP ports, 2 10GBase-T ports and 4 10G SFP+ port L3 Stackable* Managed Switch
DGS-3130-54S/B
48 1000Base-X SFP ports, 2 10GBase-T ports and 4 10G SFP+ port L3 Stackable Managed Switch
DGS-3130-54PS
48 10/100/1000Base-T PoE ports, 2 10GBase-T ports and 4 10G SFP+ port L3 Stackable Managed Switch
DGS-3130-54TS
48 10/100/1000Base-T ports, 2 10GBase-T ports and 4 10G SFP+ port L3 Stackable* Managed Switch
DGS-3620-28TC
28-Port Gigabit L3 Stackable Managed Switch including 4 x Combo 1000BASE-T/SFP ports and 4 x SFP+ 10 Gbps ports
DGS-3630-28PC
20 10/100/1000BASE-T PoE ports + 4 Combo 10/100/1000BASE-T PoE/SFP ports + 4 10 GbE SFP+ ports L3 Stackable Managed Switch
DGS-3630-52PC
10 Gigabit Ethernet Yönetilebilir Yığınlanabilen L3 Anahtarlar
DXS-3600-16S
Switch with 8 fixed SFP + ports with one expansion module, one AC power supply and three fans
Layer 3 Yığınlanabilir 10G Yönetilebilir Anahtar Serisi
5000 Series Data Center Switches
DQS-5000-32Q28
32-port 100G QSFP28 interfaces data center switch with 2 front-to-back AC PSUs, 4 front-to-back fan modules
DQS-5000-32S
32-port 40G QSFP+ interfaces data center switch with 2 front-to-back AC PSUs, 4 front-to-back fan modules
DQS-5000-54SQ28
48-port 25G SFP28, 6-port 100G QSFP28 interfaces data center switch with 2 front-to-back AC PSUs, 4 front-to-back fan modules
DXS-5000-54S
48-port 10G SFP+, 6-port 40G QSFP+ interfaces data center switch with 2 front-to-back AC PSUs, 4 front-to-back fan modules
DXS-FAN5K
Kablosuz Erişim Noktası Yönetim Anahtarları
DWS-3160-24TC
Unified Switch to manage the access points level 2 + 20-port 10/100/1000Base-T + 4 Combo 10/100/1000Base-T/SFP, supports up to 48 access points
Şasi (Chassis) Switch Ailesi
DGS-6604
Dlink DGS-6600 serisi şase orta ve geniş ölçekli kurumsal ağlar için tasarlanmıştır. Orta ölçekteki ağlar için omurga switch (Core switch), büyük ölçekli ağlar için dağıtım switch (distribution switch) olarak kullanılabilir.
DGS-6608
DGS-6600-24SC2XS
12-port SFP and 12 combo ports (10/100/1000Base-T/SFP Module) and 2-ports 10G SFP+ Module
DGS-6600-24SC2XS-C
12 ports GE SFP + 12 ports 10/100/1000Base-T/SFP Combo + 2 ports 10GE SFP+ Module with MPLS function
GBIC / mini GBIC (SFP) Transceivers
DEM-210/10/B1
1-port 100Base-FX tek modlu fiber optik kablo, 3.3V (15 km) SFP modülü
DEM-211
100Base-FX Multi-Mode SFP transceiver (up to 2 km)
DEM-220R
100Base-BX-U Single-Mode SFP transceiver (up to 20 km), Tx:1310 nm, Rx:1550 nm
DEM-220T
100Base-BX-D Single-Mode SFP transceiver (up to 20 km), Tx:1550 nm, Rx:1310 nm
DEM-310GT
1000Base-LX Single-Mode SFP transceiver (up to 10 km)
DEM-311GT
1000Base-SX Multi-Mode SFP transceiver (up to 550 m)
DEM-312GT2
1000Base-SX+ Multi-Mode SFP transceiver (up to 2 km)
DEM-314GT
1000Base-LHX Single-Mode SFP transceiver (up to 50 km)
DEM-315GT
1000Base-ZX Single-Mode SFP transceiver (up to 80 km)
DEM-330R
1000Base-BX-U Single-Mode WDM SFP transceiver (up to 3/10 km), Tx:1310 nm, Rx:1550 nm
DEM-330T
1000Base-BX-D Single-Mode WDM SFP transceiver (up to 3/10 km), Tx:1550 nm, Rx:1310 nm
DEM-331R
1000Base-BX-U Single-Mode WDM SFP transceiver (up to 20/40 km), Tx:1310 nm, Rx:1550 nm
DEM-331T
1000Base-BX-D (Tx:1550 nm, Rx:1310 nm) Single-Mode WDM SFP transceiver (up to 20/40 km)
DEM-410T
10GBase-T Copper SFP+ transceiver (up to 30 m)
DEM-436XT-BXD
10GBase-ER (Tx:1330 nm, Rx:1270 nm) Single-Mode WDM SFP transceiver (up to 40/20 km)
DEM-436XT-BXU
10GBase-ER Single-Mode WDM SFP+ transceiver (up to 40 km / 20km), Tx:1270 nm, Rx:1330 nm
DGS-703
1000Base-LX Single-Mode GBIC Transceiver (up to 10 km)
DGS-707
1000Base-SX Multi-Mode GBIC Transceiver (up to 550 m)
DGS-712
1000Base-T Copper SFP Transceiver (up to 100 m)
DIS-S330T
1000Base-BX-D (Tx:1550 nm, Rx:1310 nm) Single-Mode WDM SFP transceiver (up to 30 km)
XFP Transceivers
SFP28 tranceivers
DEM-S2801SR
25GBase-SR Multi-mode OM3 (70 m) / OM4 (100 m) SFP28 Transceiver
DEM-S2810LR
25GBase-LR Single-mode (10 km) SFP28 Transceiver
40G QSFP+ Modüller
DEM-QX01Q-SR4
40GBase-SR4 Multi-mode OM3 (100 m) / OM4 (150 m) QSFP+ Transceiver
DEM-QX10Q-LR4
40GBase-LR4 Single-mode QSFP+ Transceiver (up to 10 km)
QSFP28 tranceivers
Stack Cables
DEM-CB100Q28
Passive Copper 100G QSFP28 Direct Attach Cable, 1 m
DEM-CB100QXS-4XS
40G Passive QSFP+ Twinaxial Direct Attach Cable, 1m
DEM-CB300QXS
Passive 40G QSFP + cable for direct connection to a length of 3 meters
DEM-CB700S
DEM-CB300S
Passive 10G SFP + cable for direct connection, 3m
DEM-CB100S
Passive 10G SFP + cable for direct connection 1m
DEM-CB50CXP
Passive 120G CXP cable organization Stack
DEM-CB50
Passive 10G CX4 cable for direct connection to a length of 50 cm
Yedek Güç Kaynağı (RPS)
DPS-CB150-2PS
The power cable length 1.5 meters for connecting a backup power source to the switches
SNMP Network Yönetim Yazılımı
D-View 8
D-View 8 Network Management Software
Reconditioned Equipment
DES-3200-18_RFB
16 10/100Base-TX ports + 1 100/1000Base-X SFP port + 1 Combo 100/1000Base-T/SFP port L2 Managed Switch
DES-3200-26_RFB
24 10/100Base-TX ports + 2 Combo 100/1000Base-T/SFP ports L2 Managed Switch
DES-3200-28F_RFB
24 10/100Base-TX ports + 4 Combo 100/1000Base-T/SFP ports L2 Managed Switch
DES-3828_RFB
24 10/100Base-TX ports + 2 100/1000Base-T ports + 2 Combo 1000Base-T/SFP ports L3 Managed Switch
